  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Mill Auto Parts Loader
    • Product Image
      Multi-Axis
      • Multi-Axis
      • Five-Axis
      • Y-Axis
    • Haas Lathes
      • Bar Feeder
      • Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE
      What to Talk to Someone?
      A Haas Factory Outlet (HFO) can answer your questions and walk you through your best options.
      Contact Your Distributor >
  • Options
    • Product Image
    • Product Image
    • Product Image
      Multi-Axis Machining
      • Multi-Axis Machining
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      test title
      test title test 2
  • Service
    • Alarm Quick Search
      ALARM QUICK SEARCH
      Enter the alarm code to find related troubleshooting and how-to guides.
      No matching alarm was found for the given alarm code.
      search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
  • Videos
  • My Haas
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
My Cart
Guest Order History Sign In Register My Account Sign Out Welcome, My Machines Latest Activity My Quotes My Account My Users Sign Out
Find A Dealer
    3. Español
    13. Русский
    15. 简体中文
    19. 한국어
    20. български
    21. Slovenský
    22. Slovenščina
Search
Pallet Pool, UMC (PALLET POOL-UMC)
LAST CHANCE TO SAVE! DON’T MISS OUT!
SALE ENDS THIS MONTH!
OUR BIGGEST SALE OF THE YEAR ENDS 9/30/2019! (We really mean it!)
SAVE NOW
8-Station Pallet Pool, UMC
    CNY ONLY
High-volume production, unattended operation
  • 8+1 Stations
  • 15.75" x 11.75" Pallet Size
  • Overview
  • Details
  • Send Info
Our 8-station pallet pool for the UMC-1000/SS is perfect for high-volume production runs, or high-mix/low-volume machining. The pallets can be scheduled individually according to priority and sequencing requirements, allowing high-priority parts to be machined first or staged more often. Completed pallets are returned automatically to the holding location, or can be sequenced to a protected operator station for immediate unloading and re-loading. NOTE: The pallet pool must be ordered with the machine.
  • Fully integrated solution for lights-out production
  • 8+1 pallets (8 storage locations + 1 machining station)
  • Includes 50+1 Side-Mount Tool Changer
  • 200 lb max payload per pallet (workpiece + workholding)
  • 12" dia. x 21" tall work envelope
  • Easy-to-use scheduling interface in the Haas control
  • Dedicated load/unload station
  • Must be ordered with the machine
  • Layout Drawing
  • Owner’s Manual
UMC Pallet Pool Overview
The Pallet Pool option available on Haas UMC-Series Universal Machining Centers is designed for high-volume production and unattended operation. This manufacturing solution also excels at high-mix/low-volume part runs, because the user can assign a specific part program for each pallet. Each time that pallet is moved into the machining area, the control will automatically call the assigned part program.
UMC Pallet Pool Specifications
  INCH METRIC
Number of Stations 8 + 1 8 + 1
Number of Pallets
Pallet Length
15.75 in 400 mm
Pallet Width
11.75 in
298 mm
Maximun Pallet Load
200 lb
90.7 kg
Maximum Part Diameter (Workholding + Workpiece) 12.0 in
305 mm
Maximum Part Height (Workholding + Workpiece) 21.0 in 533 mm
UMC Pallet Schedule Table
Pallet Schedule Table Interface
The simplified Pallet Schedule Table (PST) controls pallet scheduling functions from a dedicated screen. Pallets can be scheduled individually according to priority and sequencing requirements.
  • Each Pallet is identified with a number (1 through 9), and each storage location within the Pallet Pool and machine is identified with a letter (A through I). The storage locations do not change, but the pallet ID numbers move, so you can quickly see where any pallet is at any time. Translucent numbers indicate a pallet’s destination, while the pallet pool is in motion.
  • The LOAD ORDER column indicates the scheduled priority of each pallet. Schedule pallets by pressing the Pallet Schedule button at the load station on the pallet pool, by pressing the F2 key while the desired pallet is highlighted on the PST, or by simply entering a number in the LOAD ORDER column for that pallet.
  • Highlight the PROGRAM NAME column for a pallet, and press ENTER to navigate the programs list and select which program to run each time that pallet is loaded into the machine.
  • One-Touch function keys from the PST simplify common tasks when operating the machine.
    • Press ALTER to load the highlighted pallet into the machine and activate its designated program.
    • Press INSERT to run the active program. This button starts the cycle in “Pallet Mode.” Pallet Mode will interpret an M199 code as: “load the next-scheduled pallet, and run its assigned program” (see below).
    • Press F2 to schedule the highlighted pallet.
    • Press F3 to send the pallet on the Load Station (Shelf A) to an empty station in the pallet pool.
    • Press F4 to bring the highlighted pallet to the Load Station (Shelf A).
We developed a new M-code for use with Automatic Pallet Changers. M199 is typically used at the end of a program. When the program is started by pressing [CYCLE START] in Memory mode, the M199 acts exactly like an M30 (Program End and Reset). But if the program is started by pressing [INSERT] while the Pallet Schedule Table is displayed (PALLET MODE), the M199 will command a pallet change to load the next scheduled pallet, and then run the program associated with that pallet. This allows the user to start machining on any pallet, even a mid-program start, and continue uninterrupted machining as long as pallets are scheduled.
Talk to Us
Available on These Machines
Haas UMC-1000
UMC-1000
5-Axis CNC Vertical mill with 40" x 25" x 25" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Haas UMC-1000
UMC-1000SS
Super-Speed 5-Axis CNC Vertical Mill with 40" x 25" x 25" travels
  • 40 Taper
  • 5 Axis
  • 12k RPM
    CNY ONLY
FIND DISTRIBUTOR
  • Machine Pre-Installation Guide
  • Rotary Fit Chart
  • Visit the Factory
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Functional Cookies
Analytics Cookies
