UMC-1000
5-Axis CNC Vertical mill with 40" x 25" x 25" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
5-axis machining is an effective means to reduce setups and increase accuracy for multi-sided and complex parts. The larger travels and bigger platter of the Haas UMC-1000 Series Universal Machining Centers make them perfect solutions for 3+2 machining and simultaneous 5-axis machining of large parts.
  • 5-axis simultaneous machining
  • Powerful inline direct-drive spindle
  • Large capacity side-mount tool changer
  • Includes Wireless Intuitive Probing System
  • Made in the USA
BIGGER PARTS? NO PROBLEM!
The UMC-1000 is the perfect choice for shops wanting an easy-to-use 5-axis solution to handle larger parts. It offers the same shop-proven performance and value as our super popular UMC-750, but with larger travels and a bigger platter.
Standard Features
  • 8100-rpm Spindle
  • 30+1 Side-Mount
  • Wireless Intuitive Probing System
  • Rotary-Axis Calibration Tool
  • 55-Gallon Coolant Tank
  • Media Display M-Code; M130
  • Ethernet Interface
  • Remote Jog Handle with Color LCD
  • Rigid Tapping
  • Dynamic Work Offsets and Tool Center Point Control
  • Second Home Position
  • Internal High-Voltage Isolated Transformer
  • Rotary Scales
  • Top Cover with Mist Extraction Provision
Warranty
  • 1-Year Standard Warranty
Overview
The UMC-1000 offers larger travels and a bigger platter than the UMC-750, and incorporates a number of design improvements.
Universal Machining Center Design Improvements:
  • Cycloidal Rotary Drives
  • Lighter Operator Door
  • Front-Mounted Control Pendant
  • Easy-Access Operator Convenience Features
  • Larger Side-Window
  • Stiffer Base Casting
  • Standard Rollaway Coolant Tank
The cycloidal rotary drive system – designed for machine tools and robotics – provides a great combination of speed, accuracy, and durability on both the B and C axes. The rugged design provides long service life, with little or no maintenance, and is especially durable in a crash. The cycloidal rotary drive can be back driven to absorb energy from an impact. The shock-load capacity is 5 times the rated torque of the gearbox, and the entire gearbox is a simple drop-in replacement, should damage occur.
Operator Door Improvements
The UMC-1000 door mounts inside the enclosure, which raises the bottom of the enclosure opening, and provides better chip control.
Control Pendant Mount
The internal mounting design of the UMC-1000 door allows the control pendant to be mounted to the front of the machine, in an operator-friendly position.
The UMC-1000’s operator convenience features are mounted to the front of the machine for easy access, including a toolholder storage rack, work table, toolholder vise, storage tray, and washdown hose.
Side-Window Design
Moving the control pendant to the front of the UMC-1000 allowed us to enlarge the side window and make it slide open. This provides access to the machine’s platter, and also allows a pallet pool or other automation to be added to the machine.
Base Casting and Coolant Tank
The UMC-1000 base casting is stiff and compact, improving cut performance, and allowing the use of our standard 55-gallon (208 liter) rollaway coolant tank, for easy cleaning and maintenance. An optional 95-gallon (360 liter) coolant tank is also available, and both tanks accept our Oil Skimmer and Coolant Refill options to further enhance productivity.
Travels S.A.E METRIC
X Axis 40.0 in 1016 mm
Y Axis 25.0 in 635 mm
Z Axis 25.0 in 635 mm
Spindle Nose to Platter (~ max) 29.0 in 737 mm
Spindle Nose to Platter (~ min) 4.0 in 102 mm
Spindle S.A.E METRIC
Max Rating 30.0 hp 22.4 kW
Max Speed 8100 rpm 8100 rpm
Max Torque 90 ft-lbf @ 2000 rpm 122 Nm @ 2000 rpm
Taper CT or BT 40 CT or BT 40
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Cooling Air Cooled Air Cooled
B Axis – Tilt S.A.E METRIC
Travel 120 ° to 35- ° 120 ° to 35- °
Max Speed 50 °/sec 50 °/sec
Max Torque 2240 ft-lbf 3037 Nm
Brake Torque 2000 ft-lbf 2712 Nm
C Axis – Rotation S.A.E METRIC
Travel 360 ° 360 °
Max Torque 1854 ft-lbf 2514 Nm
Max Part Swing 34.0 in 864 mm
Brake Torque 900 ft-lbf 1220 Nm
Platter S.A.E METRIC
Platter Diameter 25.00 in 635 mm
Max Weight on Platter 1000 lb 454.0 kg
T-Slot Width 0.630 in 16 mm
T-Slot Center Distance 4.92 in 125 mm
Number of Std T-Slots 5 5
Feedrates S.A.E METRIC
Max Cutting 650 ipm 16.5 m/min
Rapids on X 900 ipm 22.9 m/min
Rapids on Y 900 ipm 22.9 m/min
Rapids on Z 900 ipm 22.9 m/min
Axis Motors S.A.E METRIC
Max Thrust X 3300 lbf 14680 N
Max Thrust Y 3300 lbf 14680 N
Max Thrust Z 4050 lbf 18015 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 30+1 30+1
Max Tool Diameter (full) 2.5 in 64 mm
Max Tool Diameter (adjacent empty) 5.0 in 127 mm
Max Tool Length (from gage line) 12 in 305 mm
Max Tool Weight 12 lb 5.4 kg
Tool-to-Tool (avg) 2.8 s 2.8 s
Chip-to-Chip (avg) 3.6 s 3.6 s
General S.A.E METRIC
Coolant Capacity 55 gal 208 L
Weight 15280 lb 6931.0 kg
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Domestic Pallet 168 in x 94 in x 116 in 427 cm x 239 cm x 295 cm
Export Pallet 165 in x 92 in x 101 in 420 cm x 234 cm x 257 cm
Weight 15600 lb 7077.0 kg
Domestic Pallet for Sheet Metal Crate 102 in 63 in 34 in 260 cm 161 cm 87 cm
Export Pallet for Sheet Metal Crate 102 in 63 in 34 in 260 cm 161 cm 87 cm
Weight for Sheet Metal Crate 1164 lb 528 kg
Spindle Speed 8100 rpm 8100 rpm
Spindle Power 30.0 hp 22.4 kW
Input AC Voltage (3 Phase) - High 440 VAC 440 VAC
Full Load Amps (3 Phase) - High 35 A 35 A
Dynamic Work Offsets + Tool Center Point Control = Making 5-Axis Easier
Standard On All UMC Series Universal Machining Centers
WITH DWO/TCPC THERE’S NO NEED TO:
   Place the part in the exact same location every time
    Repost the program when the fixture changes
    Repost the program if the job moves to another Haas machine
DWO/TCPC CHANGES EVERYTHING:
✓   Save time on programming and setup
   Reduce fixturing costs
   Increase your number of multi-axis operators
   Increase your productivity and profits
HAVE UMC-1000 QUESTIONS? WE HAVE THE ANSWERS.
