TM-1P
CNC Toolroom Mill with 30" x 12" x 16" travels and ATC
  • 40 Taper
  • 3 Axis
  • 6k RPM
  • 10 Tool Capacity
The TM-P Series Toolroom Mills are affordable, easy to use, and offer the precision control of the Haas CNC system. They use standard 40-taper tooling, and are very easy to learn and operate – even without knowing G-code. They are the perfect option for schools and companies transitioning to CNC, or for anyone looking for a large-travel machine on a budget.
The TM-P models include a 10-pocket automatic tool changer, a faster spindle, and higher rapids.
  • Operates on single- or three-phase power
  • Conversational programming system
  • User-friendly Haas control
  • Affordable full CNC capabilities
  • HaasConnect remote monitoring
  • Made in the USA
Standard Features
  • 6000-rpm Spindle
  • 10-Pocket Carousel
  • Coolant Pump Kit
  • Media Display M-Code; M130
  • Ethernet Interface
  • Visual Part Programming System
  • Internal High-Voltage Isolated Transformer
  • Work Light
  • Convenience Package
Shipping
  • Lifting Provision
Warranty
  • 1-Year Standard Warranty
Travels S.A.E METRIC
X Axis 30.0 in 762 mm
Y Axis 12.0 in 305 mm
Z Axis 16.0 in 406 mm
Spindle Nose to Table (~ max) 20.0 in 508 mm
Spindle Nose to Table (~ min) 4.0 in 102 mm
Spindle S.A.E METRIC
Max Rating 7.5 hp 5.6 kW
Max Speed 6000 rpm 6000 rpm
Max Torque 33 ft-lbf @ 1200 rpm 45 Nm @ 1200 rpm
Drive System Direct Speed, Belt Drive Direct Speed, Belt Drive
Taper CT or BT 40 CT or BT 40
Bearing Lubrication Grease Packed Grease Packed
Cooling Air Cooled Air Cooled
Table S.A.E METRIC
Length 47.8 in 1213 mm
Width 10.5 in 267 mm
T-Slot Width 0.630 in 16 mm
T-Slot Center Distance 4.00 in 102 mm
Number of Std T-Slots 3 3
Max Weight on Table (evenly distributed) 1000 lb 454 kg
Feedrates S.A.E METRIC
Max Cutting 400 ipm 10.2 m/min
Rapids on X 400 ipm 10.2 m/min
Rapids on Y 400 ipm 10.2 m/min
Rapids on Z 400 ipm 10.2 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2000 lbf 8896 N
Max Thrust Y 2000 lbf 8896 N
Max Thrust Z 2000 lbf 8896 N
Tool Changer S.A.E METRIC
Type Carousel Carousel
Capacity 10 10
Max Tool Diameter (full) 3.5 in 89 mm
Max Tool Weight 12 lb 5.4 kg
Tool-to-Tool (avg) 5.7 s 5.7 s
Chip-to-Chip (avg) 6.5 s 6.5 s
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Domestic Pallet 100 in x 78 in x 99 in 254 cm x 199 cm x 252 cm
Export Pallet 100 in x 78 in x 99 in 254 cm x 199 cm x 252 cm
Weight 4500 lb 2042.0 kg
Spindle Speed 6000 rpm 6000 rpm
Spindle Power 7.5 hp 5.6 kW
Input AC Voltage (1 Phase) 220 VAC 220 VAC
Full Load Amps (1 Phase) 40 A 40 A
Full Load Amps (3 Phase) - Low 25 A 25 A
Input AC Voltage (3 Phase) - High 440 VAC 440 VAC
Full Load Amps (3 Phase) - High 13 A 13 A
Talk to Us
See the TM Series in Action
How to Square and Indicate a Vise
If you’ve ever struggled to set up a vise, or are not sure of the correct way to do it, this video is for you. Tip-of-the-Day expert Mark Terryberry shows you how.
Haas Wireless Intuitive Probing System
With the Haas Wireless Intuitive Probing System (WIPS), you can set tool and work offsets in a fraction of the time. No more edge finders or slips of paper under the tool needed.
How to Correctly Pick Up a Bore
In this video, Haas Tip-of-the-Day expert Mark Terryberry covers a topic that every machinist needs to know. Whether you are a beginner or an experienced pro, you will benefit from this video.
Use G53 Instead of G28 to Send Your Haas Mill to Home Position
Are you using a G28 command to send your machine table or tools to home position? In this Tip-of-the-Day, Mark demonstrates how using a G53 command instead not only saves valuable cycle time, but also reduces the risk of crashing your machine.
Other Similar Machines
