GR-510
CNC Gantry Router with 121" x 61" x 11" travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 10 Tool Capacity
The Haas GR Series gantry routers have the power to cut aluminum and other metals, as well as the speed to cut plastics and other light materials. These machines easily handle large sheets of material, or can machine small parts by the thousand. The rigid steel construction of the GR Series provides a very stable cutting platform, and a 1" thick aluminum table is standard. A traveling guard protects the operator from chips and coolant, and keeps the workspace clean.
  • Rigid-steel construction
  • Traveling guard for chip and coolant containment
  • 1" thick aluminum table
  • Made in the USA
Standard Features
  • 8100-rpm Spindle
  • 10-Pocket Carousel
  • Chip and Coolant Guard
  • Media Display M-Code; M130
  • Ethernet Interface
  • Internal High-Voltage Isolated Transformer
  • Aluminum Table
Warranty
  • 1-Year Standard Warranty
Travels S.A.E METRIC
X Axis 121.0 in 3073 mm
Y Axis 61.0 in 1549 mm
Z Axis 11.0 in 279 mm
Spindle Nose to Table (~ max) 13.5 in 343 mm
Spindle Nose to Table (~ min) 2.5 in 64 mm
Spindle S.A.E METRIC
Max Rating 15.0 hp 11.2 kW
Max Speed 8100 rpm 8100 rpm
Max Torque 48 ft-lbf @ 1500 rpm 65 Nm @ 1500 rpm
Drive System Direct Speed, Belt Drive Direct Speed, Belt Drive
Taper CT or BT 40 CT or BT 40
Table S.A.E METRIC
Length 122.0 in 3099 mm
Width 53.0 in 1346 mm
Max Weight on Table (evenly distributed) 6000 lb 2722 kg
Between Columns 62 in 1575 mm
Feedrates S.A.E METRIC
Max Cutting 800 ipm 20.3 m/min
Rapids on X 800 ipm 20.3 m/min
Rapids on Y 2100 ipm 53.3 m/min
Rapids on Z 1100 ipm 27.9 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2520 lbf 11210 N
Max Thrust Y 1020 lbf 4537 N
Max Thrust Z 2050 lbf 9119 N
Tool Changer S.A.E METRIC
Type Carousel Carousel
Capacity 10 10
Max Tool Diameter (full) 3.5 in 89 mm
Max Tool Weight 12 lb 5.4 kg
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Domestic Pallet 206 in x 111 in x 109 in 524 cm x 282 cm x 277 cm
Export Crate 206 in x 11 in x 112 in 524 cm x 282 cm x 285 cm
Weight 19400 lb 8800.0 kg
Domestic Pallet w/EC Option 206 in 111 in 114 in 524 cm 282 cm 290 cm
Export Crate w/EC Option 206 in 111 in 117 in 524 cm 282 cm 298 cm
Weight w/EC Option 19600 lb 8891 kg
Domestic Pallet w/EZ24 Option 206 in 111 in 125 in 524 cm 282 cm 318 cm
Export Crate w/EZ24 Option 206 in 111 in 130 in 524 cm 282 cm 331 cm
Weight w/EZ24 Option 20000 lb 9072 kg
Spindle Speed 8100 rpm 8100 rpm
Spindle Power 15.0 hp 11.2 kW
Input AC Voltage (3 Phase) - High 440 VAC 440 VAC
Full Load Amps (3 Phase) - High 20 A 20 A
Talk to Us
HaasBuilt - GR-510
Take a closer look at how your GR-510 is built and assembled from the ground up, straight from our factory in Oxnard, California!
See the GR Series in Action
Haas Second Home Option
There’s no need to lean into your machine to retrieve your tools. In this video, Mark shows us a better way.
Faster tapping with setting 130
Shorten tapping cycles dramatically by speeding up tap retracts. In this Tip of the Day, Mark breaks down setting 130 step-by-step, and explains how it can save you valuable cycle time.
Command a safe tool change position
In this video, Mark shows how to command a safe tool change position to avoid crashing a tool into your fixture or rotary. It’s all done with a simple program, and referenced with an M-code.
Display Pictures and Videos on Your Haas Control Using M130
With M130, you can display setup sheets, tool lists, work instructions, and even videos – all within your program. No more taping work instructions to the machine, or hand writing notes telling your operator how to load or inspect a part; put it all in your NC program!
Other Similar Machines
