  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Mill Auto Parts Loader
    • Product Image
      Multi-Axis
      • Multi-Axis
      • Five-Axis
      • Y-Axis
    • Haas Lathes
      • Bar Feeder
      • Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE
      What to Talk to Someone?
      A Haas Factory Outlet (HFO) can answer your questions and walk you through your best options.
      Contact Your Distributor >
  • Options
    • Product Image
    • Product Image
    • Product Image
      Multi-Axis Machining
      • Multi-Axis Machining
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      test title
      test title test 2
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • My Haas
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
My Cart
Guest Order History Sign In Register My Account Sign Out Welcome, My Machines Latest Activity My Quotes My Account My Users Sign Out
Find A Dealer
    3. Español
    13. Русский
    15. 简体中文
    19. 한국어
    20. български
    21. Slovenský
    22. Slovenščina
Search
GM-2
LAST CHANCE TO SAVE! DON’T MISS OUT!
SALE ENDS THIS MONTH!
OUR BIGGEST SALE OF THE YEAR ENDS 9/30/2019! (We really mean it!)
SAVE NOW
GM-2
    CNY ONLY
    CNY ONLY
3-Axis CNC Gantry Mill
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
* Available in North America and the UK Q4 2019. Available everywhere 2020.
  • Overview
  • Specs
  • Send Info
  • Gallery
The GM-2 is a heavy-duty 3-axis gantry mill designed for large-part machining, such as airframe components, large plates, and long extrusions. The machine’s rigid steel construction provides a very stable cutting platform, and a 1" thick aluminum table is standard. A traveling guard protects the operator from chips and coolant, and keeps the workspace clean.
  • Robust 40-taper inline direct-drive spindle
  • 75" between columns for large parts
  • Rigid-steel construction
  • Traveling guard for chip and coolant containment
  • 1" thick aluminum table
  • Made in the USA
  • Layout Drawing
  • Owner’s Manual
Travels S.A.E METRIC
X Axis 145.0 in 3683 mm
Y Axis 87.5 in 2223 mm
Z Axis 22.0 in 559 mm
Spindle Nose to Table (~ max) 26.0 in 660 mm
Spindle Nose to Table (~ min) 4.0 in 102 mm
Spindle S.A.E METRIC
Max Rating 30.0 hp 22.4 kW
Max Speed 8100 rpm 8100 rpm
Max Torque 90.0 ft-lbf @ 2000 rpm 122.0 Nm @ 2000 rpm
Taper CT or BT 40 CT or BT 40
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Cooling Liquid Cooled Liquid Cooled
Table S.A.E METRIC
Length 144.0 in 3658 mm
Length (Work Area) 72.00 in 1829 mm
Thickness 1.0 in 25 mm
Max Weight on Table (evenly distributed) 6000 lb 2722 kg
Between Columns 75.0 in 1905 mm
Feedrates S.A.E METRIC
Max Cutting 800 ipm 20.3 m/min
Rapids on X 800 ipm 20.3 m/min
Rapids on Y 2100 ipm 53.3 m/min
Rapids on Z 1100 ipm 27.9 m/min
Axis Motors S.A.E METRIC
Max Thrust X 4500 lbf 20017 N
Max Thrust Y 1650 lbf 7340 N
Max Thrust Z 2000 lbf 8896 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 30+1 30+1
Max Tool Diameter (full) 2.5 in 64 mm
Max Tool Diameter (adjacent empty) 3.5 in 89 mm
Max Tool Length (from gage line) 11 in 279 mm
Max Tool Weight 12 lb 5.4 kg
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Weight 20000 lb 9072.0 kg
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Domestic Pallet 226 in x 143 in x 109 in 574 cm x 363 cm x 277 cm
Export Crate 226 in x 153 in x 127 in 574 cm x 389 cm x 323 cm
Weight 20200 lb 9190.0 kg
Export Crate for Sheet Metal 89 in 57 in 50 in 226 cm 145 cm 126 cm
Weight for Sheet Metal Crate 1400 lb 1400 lb
Spindle Speed 8100 rpm 8100 rpm
Spindle Power 30.0 hp 22.4 kW
Table S.A.E METRIC
Type SMTC SMTC
Capacity 30+1 30+1
Table S.A.E METRIC
Type SMTC SMTC
Capacity 30+1 30+1
Table S.A.E METRIC
Type SMTC SMTC
Capacity 30+1 30+1
Talk to Us
FIND DISTRIBUTOR
  • Machine Pre-Installation Guide
  • Rotary Fit Chart
  • Visit the Factory
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
