GM-2-5AX
5-Axis CNC Gantry Mill
  • HSK 63F Taper
  • 5 Axis
  • 20k RPM
  • 30+1 Tool Capacity
The GM-2-5AX is a 5-axis gantry mill designed for complex, large-part machining, such as airframe components, layup molds, and composite structures. The machine’s rigid steel construction provides a very stable cutting platform, and a 1" thick aluminum table is standard. A traveling guard protects the operator from chips and coolant, and keeps the workspace clean.
  • Dual-axis spindle head provides ±245 degrees of C-axis rotation and ±120 degrees of B-axis tilt
  • 20,000-rpm HSK 63F spindle
  • Rigid-steel construction
  • Traveling guard for chip and coolant containment
  • 1" thick aluminum table
  • Made in the USA
LARGE TRAVELS, 5-AXIS VERSATILITY
Whether you’re machining large airframe components, trimming complex composite structures, or shaping massive layup molds, the GM-2-5AX has the capacity and capability to handle even your largest parts. The 20,000-rpm HSK 63F spindle provides the speed and rigidity you need for long tools and high surface feeds, and the dual-axis spindle head allows you to reach nearly an surface for machining complex contours and difficult features.
Standard Features
  • 20,000-rpm Spindle, HSK-63F
  • Rotary-Axis Calibration Tool
  • CNC Control Cabinet Cooler
  • Media Display M-Code; M130
  • Ethernet Interface
  • Remote Jog Handle with Color LCD
  • Rigid Tapping
  • Dynamic Work Offsets and Tool Center Point Control
  • Second Home Position
  • Aluminum Table
Warranty
  • 1-Year Standard Warranty
Travels S.A.E METRIC
X Axis 145.0 in 3683 mm
Y Axis 87.5 in 2223 mm
Z Axis 39.4 in 1000 mm
Spindle Nose to Table (~ max) 37.0 in 940 mm
Spindle Nose to Table (~ min) 5.0 in 127 mm
Spindle S.A.E METRIC
Max Rating 13.4 hp 10.0 kW
Max Speed 20000 rpm 20000 rpm
Max Torque 11 ft-lbf @ 7500 rpm 15 Nm @ 7500 rpm
Drive System Integral Spindle/Motor Integral Spindle/Motor
Taper HSK-63F HSK-63F
Bearing Lubrication Grease Packed Grease Packed
Cooling Liquid Cooled Liquid Cooled
B Axis – Tilt S.A.E METRIC
Travel 120 ° to 120- ° 120 ° to 120- °
Max Speed 110 °/sec 110 °/sec
Max Torque 752 ft-lbf 1020 Nm
C Axis – Rotation S.A.E METRIC
Travel ± 245 ° to 245- ° 245 ° to 245- °
Max Torque 760 ft-lbf 1030 Nm
Max Speed 200 °/sec 200 °/sec
Table S.A.E METRIC
Length 144.0 in 3658 mm
Width 72.0 in 1829 mm
Thickness 1.0 in 25 mm
Max Weight on Table (evenly distributed) 6000 lb 2722 kg
Between Columns 75 in 1905 mm
Feedrates S.A.E METRIC
Max Cutting 800 ipm 20.3 m/min
Rapids on X 800 ipm 20.3 m/min
Rapids on Y 2100 ipm 53.3 m/min
Rapids on Z 1100 ipm 27.9 m/min
Axis Motors S.A.E METRIC
Max Thrust X 4500 lbf 20017 N
Max Thrust Y 1650 lbf 7340 N
Max Thrust Z 2000 lbf 8896 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 30+1 30+1
Max Tool Diameter (full) 2.5 in 64 mm
Max Tool Diameter (adjacent empty) 2.5 in 64 mm
Max Tool Length (from gage line) 11 in 279 mm
Max Tool Weight 12 lb 5.4 kg
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Weight 20000 lb 9072.0 kg
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Domestic Pallet 226 in x 143 in x 136 in 574 cm x 363 cm x 345 cm
Export Crate 226 in x 143 in x 140 in 574 cm x 363 cm x 356 cm
Weight 22040 lb 10000.0 kg
Spindle Speed 20000 rpm 20000 rpm
Spindle Power 13.4 hp 10.0 kW
Full Load Amps (3 Phase) - Low 38 A 38 A
Input AC Voltage (3 Phase) - High 440 VAC 440 VAC
Full Load Amps (3 Phase) - High 19 A 19 A
Talk to Us
