DT-2
CNC Drill/Tap Center with 28" x 16" x 15.5" travels
  • 30 Taper
  • 3 Axis
  • 10k RPM
  • 20+1 Tool Capacity
The DT-2 is a compact, high-speed drill and tap machine with full milling capabilities. A powerful BT30 taper inline direct-drive spindle provides 10,000 rpm, and allows high-speed rigid tapping. A high-speed, 20-pocket tool changer swaps tools quickly, while 2400 ipm rapids and high acceleration rates shorten cycle times and reduce non-cutting time.
The DT-2 offers the same lean-style performance and benefits as the DT-1, while providing more X-axis travel and a longer table to handle larger work.
  • More X-axis travel and longer table than the DT-1
  • Powerful BT30 taper inline direct-drive spindle
  • High-productivity machining center with a compact footprint
  • Made in the USA
Introducing the DT-2
Learn about the DM-2 and DT-2 Drill/Tap/Mill Centers, and see a great cutting demo highlighting the machines’ features, like 2400 ipm rapids and ultra-fast tool changes.
Standard Features
  • 10,000-rpm Spindle
  • 20+1 Side-Mount
  • 55-Gallon Coolant Tank
  • Media Display M-Code; M130
  • Ethernet Interface
  • Rigid Tapping
  • Internal High-Voltage Isolated Transformer
  • Convenience Package
Shipping
  • Lifting Provision
Warranty
  • 1-Year Standard Warranty
HaasBuilt - DT-2
Take a closer look at how your DT-2 is built and assembled from the ground up, straight from our factory in Oxnard, California!
Travels S.A.E METRIC
X Axis 28.0 in 711 mm
Y Axis 16.0 in 406 mm
Z Axis 15.5 in 394 mm
Spindle Nose to Table (~ max) 21.5 in 546 mm
Spindle Nose to Table (~ min) 6.0 in 152 mm
Spindle S.A.E METRIC
Max Rating 15.0 hp 11.2 kW
Max Speed 10000 rpm 10000 rpm
Max Torque 46 ft-lbf @ 1700 rpm 62 Nm @ 1700 rpm
Taper BT30 BT30
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Cooling Air Cooled Air Cooled
Table S.A.E METRIC
Length 34.0 in 864 mm
Width 15.0 in 381 mm
T-Slot Width 0.630 in 16 mm
T-Slot Center Distance 4.92 in 125 mm
Number of Std T-Slots 3 3
Max Weight on Table (evenly distributed) 250 lb 113 kg
Feedrates S.A.E METRIC
Max Cutting 1200 ipm 30.5 m/min
Rapids on X 2400 ipm 61.0 m/min
Rapids on Y 2400 ipm 61.0 m/min
Rapids on Z 2400 ipm 61.0 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2550 lbf 11343 N
Max Thrust Y 2550 lbf 11343 N
Max Thrust Z 4200 lbf 18683 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 20+1 20+1
Max Tool Diameter (full) 2.0 in 51 mm
Max Tool Length (from gage line) 7 in 178 mm
Chip-to-Chip (avg) 1.6 s 1.6 s
Tapping S.A.E METRIC
Max Tapping Speed 5000 rpm 5000 rpm
General S.A.E METRIC
Coolant Capacity 55 gal 208 L
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Domestic Pallet 91 in x 100 in x 98 in 231 cm x 254 cm x 249 cm
Export Pallet 91 in x 100 in x 98 in 231 cm x 254 cm x 249 cm
Weight 5350 lb 2427.0 kg
Spindle Speed 10000 rpm 10000 rpm
Spindle Power 15.0 hp 11.2 kW
Full Load Amps (3 Phase) - Low 17 A 17 A
Input AC Voltage (3 Phase) - High 440 VAC 440 VAC
Full Load Amps (3 Phase) - High 13 A 13 A
Talk to Us
Power & Selection – Haas-Built, High-Speed Spindles
10,000-rpm
  • Standard spindle
  • Inline direct-drive
  • Great overall performance & value
  • Good performance for 3D profiling
12,000-rpm
  • High-performance option
  • High accel/decel rates
  • 5000-rpm rigid tapping
  • 20% faster speeds and feeds
  • Better performance for 3D profiling
15,000-rpm
  • 50% faster speeds and feeds
  • Best performance for 3D profiling
20,000-rpm
  • 100% faster speeds and feeds
  • Ultimate performance for 3D profiling
Note: The optional high-performance spindles have a higher power requirement than the standard spindle. Contact your local HFO for information.
See the DT/DM Series in Action
VMC Comparison
Watch as we show three of the most popular Haas mills run the same part, and see which machine finishes first.
Introduction to the DM-1
Haas Automation's DM-1 Drill/Mill Center provides the same high speed and performance as our shop-proven DT-1 Drill/Tap Center, but with a larger 40-taper inline spindle and 18+1 tool changer.
Meet your new 5-axis compact machine
If you make small parts and have multiple setups, this rotary is probably right for you. Lightning fast and accurate, the TRT100 fits in nearly every Haas mill, and will help you cut cycle times and boost your shop’s efficiency.
The DM-2 and DT-2
Bob and Bryan talk about the new Haas DM-2 and DT-2, and show a great cutting demo that highlights the machines’ features, like 2400 ipm rapids and tool changes in less than 1 second.
Other Similar Machines
