  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Mill Auto Parts Loader
    • Product Image
      Multi-Axis
      • Multi-Axis
      • Five-Axis
      • Y-Axis
    • Haas Lathes
      • Bar Feeder
      • Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE
      What to Talk to Someone?
      A Haas Factory Outlet (HFO) can answer your questions and walk you through your best options.
      Contact Your Distributor >
  • Options
    • Product Image
    • Product Image
    • Product Image
      Multi-Axis Machining
      • Multi-Axis Machining
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      test title
      test title test 2
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • My Haas
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
My Cart
Guest Order History Sign In Register My Account Sign Out Welcome, My Machines Latest Activity My Quotes My Account My Users Sign Out
Find A Dealer
    3. Español
    13. Русский
    15. 简体中文
    19. 한국어
    20. български
    21. Slovenský
    22. Slovenščina
Search
TR160-2
LAST CHANCE TO SAVE! DON’T MISS OUT!
SALE ENDS THIS MONTH!
OUR BIGGEST SALE OF THE YEAR ENDS 9/30/2019! (We really mean it!)
SAVE NOW
TR160-2
    CNY ONLY
    CNY ONLY
Dual-Platter 160 mm Trunnion Table
  • 2 Spindles
  • 160 mm Platter Size
  • 100 ft-lb Max Torque
  • 80 °/sec Max Speed
Compare Machines
BUILD & PRICE
Contact Distributor
  • Overview
  • Specs
  • Gallery
  • Send Info
The TR160-2 is a dual-axis trunnion rotary table that offers maximum rigidity and accurate performance for 3+2 and full 5-axis machining of small to medium parts. The dual-spindle design allows two workpieces to be loaded and machined in a single setup. Scale feedback on the A (tilting) axis increases positioning accuracy and repeatability. The unit fits into VF-2 and larger VF Series machines (extended Z-axis clearance option highly recommended).
Requires a Haas mill with 4th- and 5th-axis drives and software version 18.00 or later for true 4th- and 5th-axis operation. Scale feedback functional only on Haas mills with software version 18.00 or later. Scale feedback does not function with rotary control box.
  • Add 4- and 5-axis capabilities to your machine
  • Dual spindles for increased productivity
  • Easy plug-and-play connection to Haas machines
  • Industry-leading performance and capabilities
  • Made in the USA
  • Layout Drawing
  • Owner’s Manual
  • 5-Axis Rotary Series Flyer
  • Rotary Fit Chart
Platter S.A.E METRIC
Platter Diameter 6.30 in 160 mm
Part Swing Max 10.5 in 265 mm
Number of Std T-Slots 6 @ 60° 6 @ 60°
Spindle – A (tilt) S.A.E METRIC
Max Speed 80 °/sec 80 °/sec
Max Torque 150 ft-lbf 203 Nm
Backlash 30 arc-sec 30 arc-sec
Gear Ratio 63:1 63:1
Timing 2:1  2:1
Brake Torque @ 100 psi/6.9 bar 200 ft-lbf 271 Nm
Spindle – B (rotary) S.A.E METRIC
Number 2 2
Max Torque 100 ft-lbf 136 Nm
Runout Max 0.0005 in 0.013 mm
Timing 2:1  2:1
Brake Torque @ 100 psi/6.9 bar 100 ft-lbf 136 Nm
Indexing – A (tilt) S.A.E METRIC
Max Rotation/Step ± 120 ° ± 120 °
Resolution 0.001 ° 0.001 °
Accuracy (±) ± 15 arc-sec ± 15 arc-sec
Repeatability 10 arc-sec 10 arc-sec
Indexing – B (rotary) S.A.E METRIC
Max Rotation/Step (with rotary control) 999.999 ° 999.999 °
General S.A.E METRIC
Operating Temp (max ambient) 100 °F 38 °C
Air Pressure Max 150 psi 10.3 bar
Export Crate 49 in x 21 in x 25 in 125 cm x 54 cm x 64 cm
Weight 575 lb 261.0 kg
Talk to Us
CYLINDRICAL ENGRAVING USING G47/G107
Easily hand-program 4th-axis engraving on your Haas mill – without a CAM system. With G47 and G107, engraving on a cylindrical part couldn’t be easier.
UNWIND YOUR HAAS ROTARY QUICKLY
Today, Mark solves an issue every Haas Rotary user faces at some point: How do I get my rotary back to zero quickly?
How to Program a SAFE TOOL CHANGE POSITION
Mark shows how to command a safe tool change position to avoid crashing a tool into your fixture or rotary. It’s all done with a simple program, and referenced with an M-code.
Your new 5-axis compact rotary
If you make small parts and have multiple setups, this rotary is the perfect solution. Lightning fast and accurate, the TRT100 fits in nearly every Haas mill, and will help you cut cycle times and boost your shops efficiency.
Other Similar Machines
Single Rotary Spindle, More Swing
Haas TR160
TR160
160 mm Dual-Axis Trunnion Table
  • 1 Spindles
    CNY ONLY
Different Approach
Haas TRT160
TRT160
160 mm Tilting Rotary Table
  • 1 Spindles
  • 112 ft-lb Max Torque
  • 104 °/sec Max Speed
    CNY ONLY
Different Approach
Haas TR200Y
TR200Y
Compact 200 mm Dual-Axis Trunnion Table
  • 1 Spindles
  • 200 mm Platter Size
  • 150 ft-lb Max Torque
  • 130 °/sec Max Speed
    CNY ONLY
FIND DISTRIBUTOR
  • Machine Pre-Installation Guide
  • Rotary Fit Chart
  • Visit the Factory
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
