EC-1600ZT
CNC Horizontal Mill with 64" x 50" x 40" travels
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
  • 30+1 Tool Capacity
The highly popular Haas EC Series HMCs offer large work cubes and a maximum part capacity of 10,000 lb, making them perfect solutions for your large-part machining requirements. Models are available with a 4th-axis rotary platter integrated into the T-slot table to provide access to four sides of a part or tomstone, or simultaneous 4th-axis machining.
The EC-1600ZT offers more Z-axis travel than the standard EC-1600.
  • Extended Z-axis travel
  • Standard side-mount tool changer, 30 + 1 tools
  • 50-taper spindle with a 2-speed gearbox
  • Extra-large work envelope
  • 78" max part swing with integrated 4th axis (optional)
  • Made in the USA
Standard Features
  • 7500-rpm Spindle
  • 30+1 Side-Mount
  • Enclosure Exhaust System
  • Chip Auger
  • 95-Gallon Coolant Tank
  • Media Display M-Code; M130
  • Ethernet Interface
  • Remote Jog Handle with Touchscreen Display
  • Rigid Tapping
  • Internal High-Voltage Isolated Transformer
Warranty
  • 1-Year Standard Warranty
Travels S.A.E METRIC
X Axis 64.0 in 1626 mm
Y Axis 50.0 in 1270 mm
Z Axis 40.0 in 1016 mm
Spindle Centerline to Table 11.97 in 304 mm
Spindle S.A.E METRIC
Max Rating 30.0 hp 22.4 kW
Max Speed 7500 rpm 7500 rpm
Max Torque 340 ft-lbf @ 700 rpm 460 Nm @ 700 rpm
Drive System 2-Speed Gearbox 2-Speed Gearbox
Taper CT or BT 50 CT or BT 50
Table S.A.E METRIC
Length 64.0 in 1626 mm
Width 36.0 in 914 mm
T-Slot Width 0.630 in 16 mm
T-Slot Center Distance 4.92 in 125 mm
Number of Std T-Slots 7 7
Max Weight on Table (evenly distributed) 10000 lb 4536 kg
Integrated 4th Axis (B Axis) S.A.E METRIC
Table 64 in x 32 in 1626 mm x 813 mm
Platter Diameter 30.00 in 762 mm
Travel 360 ° 360 °
Max Part Swing 78.0 in 1981 mm
Max Weight on Platter 10000 lb 4536.0 kg
Max Rating 5.0 hp 3.7 kW
Rotational Torque (continuous) 2000 ft-lbf 2712 Nm
Backlash 30 arc-sec 30 arc-sec
Brake Torque 4000 ft-lbf 5423 Nm
Min Resolution 0.001 ° 0.001 °
Indexing Accuracy ± 30 arc-sec ± 30 arc-sec
Repeatability 15 arc-sec 15 arc-sec
Spindle Centerline to Table 5.75 in 146 mm
Feedrates S.A.E METRIC
Max Cutting 500 ipm 12.7 m/min
Rapids on X 600 ipm 15.2 m/min
Rapids on Y 600 ipm 15.2 m/min
Rapids on Z 600 ipm 15.2 m/min
Axis Motors S.A.E METRIC
Max Thrust X 4000 lbf 17793 N
Max Thrust Y 8000 lbf 35586 N
Max Thrust Z 8000 lbf 35586 N
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Tool Changer S.A.E METRIC
Type SMTC SMTC
Type SMTC SMTC
Capacity 30+1 30+1
Capacity 30+1 30+1
Max Tool Diameter (full) 4.0 in 102 mm
Max Tool Diameter (adjacent empty) 10.0 in 254 mm
Max Tool Length (from gage line) 20 in 508 mm
Max Tool Weight 30 lb 13.6 kg
Tool-to-Tool (avg) 4.2 s 4.2 s
Tool-to-Tool (avg) 8.0 s 8.0 s
Chip-to-Chip (avg) 12.6 s 12.6 s
Chip-to-Chip (avg) 6.3 s 6.3 s
Air Required 9 scfm @ 100 psi 255 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 7500 rpm 7500 rpm
Spindle Power 30.0 hp 22.4 kW
Input AC Voltage (3 Phase) - High 440 VAC 440 VAC
Full Load Amps (3 Phase) - High 35 A 35 A
Domestic Pallet 192 in x 166 in x 136 in 488 cm x 422 cm x 346 cm
Export Crate 192 in x 166 in x 137 in 488 cm x 422 cm x 348 cm
Weight 35000 lb 15876.0 kg
Talk to Us
See the EC Series in Action
The Redesigned EC-1600
The popular EC-1600 has received a host of improvements, making it better than ever, like a faster spindle and tool changer, more rigid castings, and new operator-convenience features.
Wireless Intuitive Probing System
With the Haas Wireless Intuitive Probing System (WIPS), you can set tool and work offsets in a fraction of the time. No more edge finders or slips of paper under the tool needed.
The Haas EC-1600ZT-5AX
We took our tried-and-true EC-1600ZT, and added 4th- and 5th-axis capabilities to create an HMC capable of full 5-axis machining on large parts.
Display Pictures and Videos on Your Haas Control Using M130
Mark shows off the powerful Haas M130 Media Display feature. By commanding an M130, you can display setup sheets, tool lists, work instructions, and even videos – all from within your program.
Other Similar Machines
